Hi all,
I’m facing issues trying to turn a polygonal mesh into a zero-thickness surface in Solidworks. This CAD surface is going to be used to create a mold where surface quality is very important. Trying to copy the mesh geometry by hand modeling has so far proved unsuccessful (someone much more skilled at CAD than me gave it a shot and couldn't get it). Unfortunately, my modeling skills and knowledge are currently pretty modest, so I was hoping you guys could help.
I’ve read through this thread, and it seemed like responses ranged from “this process is enormously tedious and requires skill” to “I (daily Rhino user) could do this in an hour.” So kind of confusing.
What I’m looking for is a tool/process that can do this simply, reliably and to a relatively high degree of precision. I’d also like to avoid anything with a steep learning curve if at all possible. I’ve looked at Mesh2Surface and this software, Geomagic, which looks a bit fancier.
As for the output file, I’m not sure whether it should be parametric or some other type of model (NURBS?). The final touches are going to be done in NX before they go to the mold maker, so I assume this means that the model should be parametric? Then again, it’s really important to get the details right, and I’ve read that parametric approximations can mess that up. Thoughts?
Thanks!
Thanks!
