leftcoastlefty
- Nov 4, 2007
- Calif
Has anyone run into this problem:
When I mirror a toolpath, the mirrored arc will be in the wrong direction. For example, when I mirrored a simple slot (line, arc, line) the two lines were correct, but the arc is backwards. I can even get it to draw the preliminary toolpath correctly, but then run the toolpath or verify and it arcs a mirror of the intended arc.
