micro wrote:
> Are you serious about parametric sketching?
Yes, we do plan to have basic relationships when editing of contours is added, but it is some way off to be honest.
SeymourDumore wrote:
> ability to use Cut-chain by selecting the first segment and direction and the last
> segment, all without having to guess what the program ( Bobcad) thinks is the
> correct path. Just follow the chain.
The concept is different in SharpCam. First you connect the contours, this is a pre machining operation. The advantage is that any ambiguity is resolved before you even try and create any toolpaths. Take a look at this video, it should explain everything:
http://www.sharpcam.co.uk/Training-C.../Contours.html
> Ability to strip EVERYTHING out of the post, so the
> finished code is nothing but the X-Y coords and the appropriate G01/G02/G03 code.
Absolutely, the Machine Definition (post processor) can be edited to your hearts content with the Machine Developer. Video:
http://www.sharpcam.co.uk/Demo-Video...Developer.html
> Ability to add feed and speed commands, comments, M-codes by hand without
> loosing syncronicity between the code and the graphics
Not available at the moment, but is certainly planned. This will be a user defined section that will appear in the operation tree and can be moved around, edited, like any other operation.
> If there is a W2K version that would be very cool.
Not possible I am afraid. SharpCam targets version 3.0 of the .Net Framework and W2K is not supported my Microsoft.
> One more thing. I'd want a better macro capability instead of the really retarded
VB
> Script included w. BobCAD
Again on list is an Add Inn Developer. This will have a full implementation of Visual Basic .Net, not to be confused with the old
VB 6.0 or scripting. The development environment will be similar to the Machine Developer. SharpCam will have an API giving access to all aspects.
If you have any further question, let me know
Julian
