New version of CNCOffsetCalculator can import dxf files together with offset positions.
You can setup offsets for your machining centre in few steps:
1. Make a sketch of your part in AutoCAD and draw points in place of offsets. Save as dxf.
2. Load the dxf into CNCOffsetCalculator - the points will be registered as offsets with Y0 and B0 value.
3. Change the Y and B values for each offset - you can pick B angle from the drawing - no typing.
4. Set your output option (G10, system vars, Excel) and click the Post CNC button.
You can also write dxf file from your sketch created in CNCOffsetCalculator - together with the offset positions - they will be converted to dxf points.
For demo download and more info visit www.cncplusplus.com
Thank you for your interest,
Zdenek
Zdenek
