Like all jobs, what a 'professional draftsman' does has changed significantly over the years. There was a time where the job was arguably as difficult as what the 'engineers' did. Ever thought about what it would take to generate a 10 or 20 sheet drawing, in D or E size, by hand, on paper? It's not just 'right-click, projected view, section view, detail view.'
As the drafting aids get better and better, it takes less and less skill and experience to be able to create useful drawings, but just like many fields, there is a lot about the job that can't really be automated well. It takes a lot of judgement to be a good drafter, and the broader their experience in the field (whether it's mechanical, electrical, architectural, whatever) the better they seem to be at the job. And a good drafter is absolutely invaluable - the best ones I have worked with had a terrific eye for detail, and often caught a lot of things engineers missed, or mistakes they made.
That said, these days it seems to be a position that doesn't exist as much as it used to on paper - i.e. not many people have the title of 'Draftsman' - although I think there are still a lot of people doing the job under different titles. It's typically become work for entry-level/intern/co-op engineers, lower level contract engineers, toolmakers stuck on light duty, or apprentice designers. I've almost always seen it relegated to people who are either newer, or only in the position temporarily, often as a way to get them familiar with the designs, standard practices, and typical work for an company or industry.
The job title 'CAD Operator' seems to be replacing 'Draftsman' quite a bit, and is definitely not a bad place to be. Just about every company I know would be willing to pick up someone who knows the software, just to take some of the load off of everyone else in the department. Added bonus if they know a bit about machining and/or inspection (which a lot of CAD operators, and entry-level engineers don't.) Triple word score if you can write, or bring with you, efficiency macros for whatever programs you're good with.
