goldenfab
Cast Iron
- May 25, 2016
- USA Prescott , Arizona
So I am completely fed up with Mach3. I have been using a FKLOP motion control board and Mach3 with the KFLOP plugin to run my mill. Yesterday it halted motion for apparently no reason which it likes to do every few hours. When I dated to cycle start again which usually works it went off path and scrapped my part. It could be my setup or PC but I have other reasons to loathe it as well, primarily because it is terrible controlling acceleration for complex surface machining via short poly-line segments.
I have started using KMotionCNC. It is night and day better controlling motion. For poly-line segments it very noticeably runs the same code much faster and smoother than the Mach3 setup.
My problem is I have not found a post processor to use. It mostly works with the Mach3 post I was using but has some issues. KMotionCNC supposedly adheres to EMC so it should work with a post designed for LinuxCNC right? I sent a request to SprutCAM and am waiting to hear back from them. If anyone knows where to get a post processor file that would work in the mean time I would be much appreciative.
-Adam
-Adam
