RussellRought
- Jan 7, 2013
- USA
FIXED How to get info to transfer to setup sheet with mastecam /active reports?
I am trying to make my own setup sheet using active reports with Mastercam. I am having an issue trying to find information about how it works.
I would like to know if there is a list somewhere that tells me what words or phrases I am allowed to use to automatically migrate info from mastercam to the output setup sheet.
I am going to reference "Setup Sheet (MILL).rpx". I assume has access to this setup sheet option.
I would like to know how, using the initial SU sheet popup, to get any info that you type into the extra lines (Revision, Note 1, Note 2...) to appear on the setup sheet. I would also like to know how to get comments into the "comments" location. I am sure it is simple. I know that you need to create a "text box" and put info into that but I need to know the right info to put into the "data field" (I assume, looking at other working text boxes). I think I just simply need a list of the different option available.
Thanks for your time
