EvolveES
- Dec 17, 2014
- Longmont, CO
Hi,
This may be a Newbie problem but i can't seem to find any answers. I am trying to draw a rectangle around a part i have imported into Mastercam X4 (imported from STEP file created in Solidworks). This is to make a pocket that had bosses in the middle but i want to clear over the edge (so the rectangle is larger than the outside of the part.
Every time i draw a rectangle where i would like it and then try to select the profile for the outer boundary of the pocket operation the rectangle is like it is made up of two curves, Mastercam wants to make two paths out if it and then tells me that the profile is not closed and will not work for the pocket operation. Is there a way to link the four lines of the rectangle together to make a closed profile, or some other way to accomplish this?
Any help is appreciated,
Thank you,
~Zach
Thank you,
~Zach
