Setup Sheet Template
Results 1 to 3 of 3
    Dec 2017
    North Carolina
    37
    18
    Default Setup Sheet Template
    Good afternoon! Does anyone have a Milling/Turning Setup Sheet Template in excel that they can share? I'm actually a CMM programmer that was pulled to do some CAM programming since in know some G-CODE.
    Dec 2008
    New York
    7,979
    2111
    Quote Originally Posted by cmmpro1 View Post
    i have seen a tool list in Excel but a setup drawing or picture often its done in Powerpoint where adding a arrow and text box to picture is what its made for. you can do same in excel but arrows move around when you resize cells and rows. in Powerpoint each sheet is independent of the others.
    Tool list is what ever you need like gagelength, dia, min and max stickout, etc some use wear comp instead of actual length and dia that way if forgotten to be put in control tool in general it is farther away (crash prevention). you have to adapt to the control you have and the parts you are making
    Dec 2017
    North Carolina
    37
    18
    Quote Originally Posted by DMF_TomB View Post
    Thank you for the info. It's been a few years since I've been a machinist. Programming from cad using Fusion 360 and Inventor.
