Siemens 802d Fusion360 post
Results 1 to 7 of 7
    Mar 2017
    Wisconsin
    29
    6
    Default Siemens 802d Fusion360 post
    Has anyone out there used Fusion-360 on a 802D Siemens control? I'm gist getting started with setting up and using my newly purchased Romi C420 (2011) model. I have figured out the manual side and some of the cnc functions. I've been able to hand write code. I sure would like to have cam. Fusion-360 seems to be the ticket but, the posts for this machine suck. I have tried the G291 mode (ISO cnc G code) and G290 (Default Siemens mode). Neither one will run without LOTS of re-coding at the machine.
    Brian
  2. Likes TopSolidCAM... liked this post
  3. #2
    Oct 2011
    Southfield, MI
    91
    9
    24
    Their 802D post is not working for you? http://cam.autodesk.com/posts/downlo...e=siemens-802d
    Mar 2017
    Wisconsin
    29
    6
    Quote Originally Posted by jeffj View Post
    Thanks Jeff but that post is for Milling. I need a better post for turning.
    Mar 2017
    Wisconsin
    29
    6
    I was hoping that someone had tackled this problem before. So far my best solution to posting to my Romi C420 using Fusion, is to use the Fanuc Turning post. Before importing to my machine I change all G50's to G92, G99's to G95 and add a G291 to the start of the code. This minimizes the code changes that have to be done at the control.
    May 2013
    Near Seattle, WA
    1,010
    252
    809
    Quote Originally Posted by bdrmachine View Post
    If you can define what needs changed from an existing post, making the post edits themselves isn't actually too difficult.
    Nov 2007
    canada
    437
    62
    167
    Whats wrong with the Siemens turning post? It is a generic turning post so you should only need minimal edits depending on the control your using. The post labeled as 802 is a milling post.
    Jan 2018
    GERMANY
    Please create a topic on the Autodesk HSM Postprocessor forum with detailed information about what is wrong with the siemens turning post output:
    HSM Post Processor Forum - Autodesk Community
  9. Likes rlockwood, Atomkinder liked this post
