Rbpercussion
- Jan 27, 2015
First off if memory at the cnc controller isn't a problem, is it (in your opinion of course) better to have more sophisticated program with a more sophisticated toolpath? Or is it better to have a simple program for the set-up operator to prove and edit? In my opinion I believe sophistication in toolpath is only necessary in production runs or a part that requires a very large amount of machining. On the simpler 2d job shop type parts though i believe basic toolpaths would be more appropriate for simplicity at the machine.
This leads to another question: If I am trying to output the simplest program via mastercam, how do I reduce the lines of code in the program down to minimal necessary? HSM techniques seem to lend themselves to long programs, but this is only my experience with the paths I've created. For example, I create a path for a rectangular contour and as the tool moves down a side of the part in a straight line I notice there is an inordinate amount of lines (according to the move list and move info) for what should just be an xy line.
