Matt@RFR
Titanium
- May 26, 2004
- Paradise, Ca
Anybody running 2005 SolidWorks and are familiar with the sheetmetal functions? I have four books on SolidWorks, plus the online tutorial, and all of them use simple boxes with 90º sides as examples. I can do that easy enough, but if I apply the same exact methods and sequences on a box with angled sides, it isn't at all happy with me. The method all my reference material suggests is to make a solid the correct shape, then rip the corners and insert bends. When I insert bends, it comes up with an error that says, "Attempt to add auto-relief failed. Could not create a bend with the given radius. Please try a different radius or add reliefs."
I've tried bend radii from zero through .750" (nominal being 1/16") with no effect, and I can't find how to add reliefs by any other means that the auto-relief function, with which I've tried numerous shapes and ratio's with no luck.
This is an 18ga mild steel part that I would really like to have to our laser/forming shop on Monday. If any of you would like to see the file, I'd be more than happy to email it to you as a solid.
As a note, I've been trying all this without the 'tail' and the flange...my thinking is that it would be easier to add those two features later.
Thanks for any help guys.
