Hi,
Please understand that I am not a business, so cannot afford expensive software so can anyone help me please.
I have a Denford Novaturn which, since I have had for about 12 months, have made little on it as I found the programming side of it a bit heavy so have learnt that I should be looking for a type of software that can make the g-code (fanuc) for me. I need something that allows me to simply draw what I want to turn (only simple things like dimensioning, threading, and boring), graphically, and then make the g-code from this.
The machine uses DOS software called FLSTEP and can run g-code.
There is a software called quickturn2D which would work it, but is costly, and apparently some functions might not work with my lathe as it is of older control firmeware, and upgrading it will cost around £1800, which for what I am gong to make on it, is much too much.
If however, anyone could sell me quickturn2D (if they are no longer using the software, of course !!), so I could try it out, that would be great, but other than that, is there anything out that is low cost (or free), that can perform this, as I have googled and googled but found nothing that is not hundreds of pounds, or only for mills and not for a lathe.
Any help would be appreciated, or you can p.m. me if you can help with the above request.
Thanks.
Thanks.
