matt_d77
- Jul 23, 2009
- Midwest usa
Our art department uses Adobe Illustrator to generate our prints and graphics, but when the files are exported to DXF of DWG they come in as splines, which creates a lot of issues for our tool room. I know in AutoCAD I can convert the splines to P-Lines but then the periphery consists of thousands of tiny line segments that are also not good for programing our CNC equipment(CNC mills and Wire EDM). Our tool room uses Esprit to program our CNC equipment, and to the best of their knowledge, there's not a good solution to the problem with that software. My question is, how do I get useable, machinable, geometry using A.I., AutoCAD, or Esprit that consists of arcs and lines? I understand that splines are approximations and some variance in geometry will likely be needed but it's got to be better than tracing the splines one segment at a time in AutoCAD. Thanks for any help or suggestions.
