SprutCAM9: How to Save Tool Federate in "in/Tooth" Unit
Results 1 to 2 of 2
    May 2016
    Arizona
    153
    5
    36
    Default SprutCAM9: How to Save Tool Federate in "in/Tooth" Unit
    Title says it all.
    I'm using SprutCAM9. I know the basics of editing/creating new tools in the tool library. For each tool I see I can save a spindle RPM and Federate. Problem is the units of feedrate are "inch per min". Does anyone know if I can save the feedrate in the units of "in per tooth" and have that being the default in the "Feeds/Speeds" page for machining operations?
    Adam
    Oct 2008
    sweden
    32
    I did a quick test in Sprutcam 10 and it worked fine to save a tool with mesurement unit set to mm per tooth.
    So it should work in inch mode to.
