Results 1 to 7 of 7
    moldmaker96 is offline Plastic
    Jul 2011
    Wisconsin USA
    29
    Default Surfcam "SYNTAX ERROR OR VIOLATION" when I click "SELECT TOOL" in drill cycle...
    I am using Surfcam velocity 5.1 B302. When I attempted to select a reamer from the metric tool table in the Select Tool window, I got a pop-up window that says "Syntax error or access violation and it will not let me select any drill tools from any table now. This happens every time I click Select Tool in the Hole Process form.
    I can, however, select tools from the Mill form when I program a milling tool path.
    Our maintenance is expired right now and can't be renewed for a few weeks yet...so no help from software distributor.
    Anyone have any ideas? Also, I already rebooted my computer...still have same problem.
    Thank you for any help!
    len_1962's Avatar
    len_1962 is online now Stainless
    Dec 2008
    tempe,arizona,usa
    1,025
    Call me at 480-205-3330 and I'll try to help you.
    I'll be WI tomarrow morning, flying tonight at 6:40pm AZ time.
    Sounds like you have something corrupted your access data base.
    Have you tried to run a repair from the cd?
    you could also try a system restore to a date that it still worked, that may fix it also.
    or last but not least a uninstall and reinstall.
    BOSTON is offline Stainless
    Oct 2006
    Boston,Mass.
    1,737
    Len going to the air show?
    zero_divide's Avatar
    zero_divide is online now Hot Rolled
    Feb 2012
    Toronto
    521
    Quote Originally Posted by moldmaker96 View Post
    Happened with me before.
    Open your DRILLTLB.MDB file in Microsoft Acess. And look for unusual stuff in there.
    IE: Tool recors with the same number. Usually it accidently adds same record number when you have 2 or more instances of Surfcam running.
    Locate the problem and Delete the record.
    Or Find a working file and replace thwe bad one with it.
    I am not sure i can upload it here tho....might violate some copyright BS. and i get banned
    len_1962's Avatar
    Dec 2008
    tempe,arizona,usa
    1,025
    wish!
    but going to packer training camp tomorrow!
    visiting Mom and family and of course beer and fish fry!!
    Jul 2011
    Wisconsin USA
    29
    Quote Originally Posted by zero_divide View Post
    THIS WORKED PERFECTLY!!! Thank you very much for your help.
    Feb 2012
    Toronto
    521
    NP. Feels nice to be useful once in a while.
