wheelieking71
- Jan 2, 2013
- Gilbert, AZ
I should know this. But, I just can't figure out anything that works.
Is it possible to create an "edge-break" that basically amounts to an undercut chamfer, with a lollipop cutter?
If there is a technique that works, I can't figure it out.
I have a side profile that has a groove cut in it. I am cutting the groove with what basically amounts to a radiused woodruff cutter.
It is closed ended, with a radiused lead-in/out. Because of that, I want to reach under the top edge (and down to the bottom for that matter),
with a lollipop to deburr the sharp edge. But, also get a nice blend at the ends which wouldn't be possible with a dovetail.
where I could just cheat the GEO around until it worked.
The lollipop throws a wrench in the works.
Am I missing something? Or is this not possible in FeatureCAM?
