Hello,
I hope this is the right section to open my post. I have a sheet with a freeform surface in a parasolid file (but i can import it in Solidworks or Creo).
I have to obtain the Gcode of a robot arm that has to "scan" vertically the surface of the sheet from only one side. I´m trying to do that using Creo Parametric but i'm just learning to use it and i didn't find anything helpful (tutorial) on the web. Do you know how can i do that using Creo? Or could you suggest me an easier and fast way to obtain the gcode from the surface?
Thank you in advance,
Best regards,
Alberto
Best regards,
Alberto
