Results 1 to 10 of 10
Thread: Tebis cam
01-08-2010, 08:19 PM #1
Tebis cam
Just wondering if anyone out there uses tebis as a cam package and if they have switch to the lastest version?
01-13-2010, 10:39 AM #2
Good luck with that one. I doubt you will find many Tebis users here. Even WorkNC users are few and far between.
02-20-2011, 05:46 AM #3
Tebis testing
We are looking at Tebis for CAM. We use Pro-NC but recemt testing on one product line shows a faster programming time (almost 50 percent faster in this case). We are considering Tebis only because we have international locations and other systems also need to be compared. But thus far Tebis has shown to be easy to learn and programmer friendly.
09-16-2012, 05:22 AM #4
09-16-2012, 12:18 PM #5
09-20-2012, 03:48 AM #6
No, WorkNC is a small fraction of that price. I had a quote for Tebis about 8 years ago and it was $75,000 a seat. WorkNC is still way, way cheaper than that.
Dan
09-21-2012, 08:50 AM #7
JD78
Just out of curiosity, why do you think Tebis is better when machining at an angle?
10-19-2012, 04:38 AM #8
you can tilt a program after it is made multiple times until it clears. i use tebis for topologies and any part area. work nc is good for drilling and tapping only. tebis keeps the cutter planted almost the entire time unlike work nc. faster machining = more profit. so it is actually cheaper in the long run to pay a little more upfront for more further down the road.
10-19-2012, 08:47 AM #9
"you can tilt a program after it is made multiple times until it clears."
Can't you do the same automatically with WorkNC's auto5 or auto3+2 functionality?
I'm not disagreeing with you, as I don't have Tebis experience to use as a point of reference. I'm just curious as to what the difference is.
Dan
11-05-2012, 12:10 PM #10
That's kind of the whole point of Auto 5 and Auto 3+2, but even in the standard package the tool orientation function in the G3 interface does a good job of finding the collision free tip angle beforehand without needing to tilt a calculated program a bunch of times after the fact. (which would seem to be limited to ball tools only, unless it's still recalculating the cutterpath)
