New CamWorks User
We just got CamWorks 2011 this year after buying a new AMS AW5SL Wire machine. I have to say, although it is different, once you understand what is needed (only 3D) and how to manipulate the settings, it does as advertised. It is an add on to Solidworks, so you'd either need SW or you can buy CW as a standalone.
I feel that the program is much more popular for milling and lathe than WEDM, but I can see it improving with each release. It took a solid month of messing around, tech support calls and practice parts even after training, to get used to the interface and learn how to extrude all the parts to ready them for machining. It is truly a WYSIWYG program, with great simulation, so you can make small changes to tweak your program before committing it to metal. You should already be versed in Solidworks or you may get lost quickly in class. We have a ton of legacy Cadkey parts to use, so extruding them is sometimes a challenge since SW needs relatively clean figures (no duplicate or overlapping lines, etc.)
The price was reasonable and the NH VAR is responsive. The best support so far came in the post processor development where they were able to customize our post the way we need it. The training was more geared toward milling (I was the only wire guy) but I got extra time and individual support to make up for it. I give CamWorks a solid B so far, compared to Esprit 2011 which gets a C-/D+. My oldest CAM program was CT Esprit, (B+) which although only 2D, ran all our Charmilles machines without disappointment.
How do you rate YOUR CAM?
