Hello HuFlungDung,
No it doesn't. When G41/42 are made active in a program, the control uses Look Ahead blocks to calculate the True Position of the Tool to compensate for the effects of the TNR of the Insert.
In the attached picture, the Green Lines indicate the coordinate points at the Start and End of the Tapered Face. If you were to command the tool to position at the coordinate represented by the Bottom Right set of Green Lines, then the Tool Nose Radius of a R/H OD Turning Tool would locate to where the Bottom Right Red Circle (Tool Nose of Insert) is shown. This is based on the normal setting of a R/H OD Turning Tool where the Leading Edge of the Insert is set for Z and the point of the TNR closest to the machine centre line is set for X. If the program were to execute a Linear Interpolation move to the coordinates represented by the Top Left set of Green Lines, then the Tool Nose Radius of a R/H OD Turning Tool would locate to where the Top Left Right Red Circle (TNR) is shown.
In making a Linear move from the location of the Bottom Right Red Circle (TNR) to the location of the Top Left Red Circle (TNR), then the Tool Nose Radius would move along the Red Line shown. The Grey Line represents the True Surface of the Work-piece. Accordingly, when the actual coordinates of the Work-piece are used in the Part Program and no TRC is used at the control by making G41/42 active, in the example of the tapered surface shown, an amount of material represented by the distance between the Red and Grey parallel lines will be left on the Work-piece.
The Yellow Circles represent the location of the TNR at the Start and End of the Tapered Surface, when:
1. the actual coordinates of the Work-piece are used in the Part Program and when TRC at the control is used by making G42 active.
2. the coordinates used in the Part Program have been calculated to compensate for the TNR of the tool being used. In this case, TRC at the control by making G42 active will NOT be used. If a TNR value and a Tool Tip Type have been registered for the Tool, they will be ignored when G41 and G42 are not active.
In the case of 1 and 2 above, the Yellow Tool Nose Radius would move along the Grey (True Surface of the Taper)
Therefore, when the Geometry Offset of a tool has been correctly set, the tool can be used with equal success in a program where TRC at the control is used (G41/42 included in the Part Program)and in programs where the Tool Compensation has been calculated and included in the coordinate values used in the Part Program and where TRC at the control is NOT used (no G41/42 applied in the Part Program). This is an example of the same Tool, using the same set of Offsets can be used in the one program in the one overall machining operation, where the part is machined with TRC turned off for some features (the Face) and on for others.
In a Work-piece where the end of the part (Z Zero - Face Perpendicular to Z axis) is faced, it is profoundly typical for TRC to be cancelled (G40), as the position of the TNR will be the same with, or without TRC active. TRC would then be made active by executing G42 when the tool is moved to the Start of the Taper.
In summary, the same tool, with the same Offset can be used to machine a Work-piece with, or without TRC being active, provided that the coordinates in the part program accommodate the use of, or not, Tool Radius Comp at the control. There will be no scrapping of parts due to the same set of Offsets being used for programs with and without TRC being calculated by the control.
Regards,
Bill
