snowluck2345
- Mar 10, 2010
- California USA
As stated above, why is CAM not fully automated? Given your work holding and sufficient machine simulation I see no technical reason it isn't possible. I'm particularly bothered by having to set surfacing profile types, why doesn't the software run an optimization algorithm to select the best one? I could see doing geometric analysis and then using genetic algorithms or simulated annealing working very well.
Do state of the art CAM softwares do this? I assume 5 axis work is very automated. I only have experience with SolidCAM and 3 axis work. Imachining3D isn't bad, but there is a lot of room for improvement.
I don't like spending an hour doing CAM for parts... I see no reason it should not be basically like 3D printing, just need to think about fixturing and your surface finish requirements. This is obviously within reason and there are limitations.
