Jaxian
Stainless
- Feb 24, 2013
- Santa Cruz
Been Googling and searching and can't find the answer so figured I would ask here.
My post's for Fusion 360 add a G10 line near the start of the program after which it doesn't actually seem to do anything but about 50 lines of code scroll by at the first tool change. I am guessing it is a macro since it has program structure.
Anyhow, first time it did this I ignored it and doing a single block watched it drop a 2" face mill 1.5" under the Z surface. Thank god no stock loaded as it was a first test. It hadn't done that in the simulation before I ran the post so needless to say the almost huge crash had me a bit startled. I checked the Offsets page on the controller (Fanuc 0i D) and the tool offset had been cut in half from what I had just preset it with the Renishaw presetter. Needless to say I was startled to find this change.
Short fix was just deleting the G10 line. After that it still runs some macro that I am not putting in the program on the first toolchange (and any toolchange after that even if I am in MDI with no program running until the controller is restarted) but it doesn't seem to effect anything.
How do I get Fusion 360 to stop putting in this G10 line and triggering whatever that macro is? I found the Tool Offset WPS in a post setup dialog box, I think it was for Stock. But it is set to 0, as was the Work Offset one above it. Not an on/off checkbox.
How do I get it to stop putting this line in? Getting sick of deleting it everytime I post something new.
Thanks guys.
Thanks guys.
