workshoprat
- Dec 8, 2012
- Bois D Arc MO
Hey I been working on this 16" lodge and shipley I got a few years back. It was made in 1916. Its been setting in my shop a while project #3982. Anyhow my drive on my ATW went down so I figured it was a good time to get it up and running so I can continue to power tread some rods I am making for making square u bolts. Anyhow I got a 3 hp motor in place of the old 1 hp. after figuring out that the oil in the headstock was way to thick and robbing way to much power I did a flush with diesel fuel and will get some good oil for it in the morning. Cant today being cristmas and all. I am figuring on running ATF.
Ok so for the big problem is all my functions work except for the cross slide feed. I think the nut is stuck but I cannot get it to budge either way. The one for the carriage feed works great. I am not even sure which way to turn it and if im tightening it making it worse or loosening it. when you turn the cross slide feed handle the power know also turns and is locked to the feed handle. does anyone have a diagram of how these come apart or have any idea of how to get this unstuck and working?
here is a pic of the machine
