Mike C.
- Nov 25, 2004
- Birmingham, AL
Friend of a friend has this problem. Pretty well spelled out in the title. Spindle will not budge. He let some "machinist" come into the shop to use the lathe and this is the result.
I looked it over today and here's the deal....With the headstock cover off, the motor runs fine, you can turn the shifter knob and all the shifters move except one. Farthest one back wiggles, but it is stuck. Countershaft in the bottom of the gearbox is also locked up (tied to spindle at rear end with bevel gears). Normally, I'd have dove in and had the headstock in pieces without hesitation, but the hydraulic shift system intimidates me. I know once that is out of the way it will be as simple as my 1918 L&S, but I don't want to screw up the hydraulics. Any help greatly appreciated.
