Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By M. Moore
Thread: 2H clutch lever and shaft?
    Steve in SoCal's Avatar
    Steve in SoCal is offline Stainless
    Oct 2006
    Woodland Hills, Ca. and some times Hutchinson, Ks.
    1,335
    Default 2H clutch lever and shaft?
    My 2h has a mishap that damaged the clutch lever and bent the shaft. I can rotate the shaft by lifting it but, I will need to remove it to straighten the end that the lever is attached to. What do I have to do to remove the shaft? Anybody parting a 2H that has a clutch lever and Y axis hand wheel?
    Steve
    beckley23 is offline Titanium
    Feb 2003
    Louisville, KY, USA
    2,885
    Lift the clutch shaft up, and put a block under it to hold it up. Remove the castle nut from the pulley end and then remove the speed box from the left side, it weighs approx 100 LBS. Use the push off screw holes at the top and bottom to help separate the box from the column. From there you should see how to get the shaft out. May have to do electrical work in the process.
    Harry
    kpotter's Avatar
    kpotter is offline Titanium
    Apr 2001
    tucson arizona usa
    3,502
    Als machinerey has one sitting in the pile in the back of the shop. Als phone number is 520-574-2776. I would be willing to ship it for you if needed. you can tell Al I sent you. I dont know what he wants for it and he can be a pain to deal with. I will let him know you might call.
    Oct 2006
    1,335
    Thank You Harry and, Kevin.
    I will call this week, is that the guy you worked for Kevin?
    Steve
    kpotter's Avatar
    Apr 2001
    tucson arizona usa
    3,502
    Yep that is the guy. I will call him in the morning he has a thing about selling parts but there is no way he is ever going to need that thing it has been sitting their for years. He wont even buy K&T horizontals you need to give them to him and deliver them.
    M. Moore's Avatar
    M. Moore is offline Stainless
    Jun 2007
    Vancouver Island, B.C. Canada
    1,101
    Steve,
    Fess up, what happened to the mill? During a move?
    Inquiring minds need to know.
    Michael
    S_W_Bausch likes this.
