gmach10
Hot Rolled
- Dec 27, 2008
- N.E. Illinois
We've got a Pacemaker serial #73258-52 at work. The lever for the half nuts has no detent left so the lever just falls into the engaged position if you don't hang on to it. A real dangerous PITA. Parts manual shows what appears to be a ball bearing with a spring behind it captured by a screw. Is this located under or behind the bracket that supports the spindle engage handle or should I be looking some place else?
