Results 1 to 3 of 3
    tbeattie01 is offline Plastic
    May 2012
    Wisconsin USA
    Angry AVENGER 250MT "AXIS NOT ALIGNED" Please Help
    Hello Forum Folks
    I have a Avenger 250 MT With subspindle.
    This machine was stored for 6 months and lost its memory. I sent the board to Siemens and hade the programs put back in and a new battery.
    When I start the machine I get the error "AXIS NOT ALIGNED" The Control and Hydraulics are on but I cant control anything to follow the Axis alignment procedure in the manuals. The only thing that works is the work light and the chuck foot pedal.
    The people at siemens are out of ideas and MAC wasn't much help either. I triple checked the Comissioning data and MTB Data with the History records and checked to make sure Siemens intall the right program and all looks good.
    I checked the I/O and it matches The Electrical Prints. All homing proxes and switches are working and showing up in the diagnostics of the Acramatic controller.
    Every other time I try to restart, the X-axis Fauls Over current. (I believe its trying to make a move with the brake on). I thought maybe the X-motor resolver was bad from moving the machine (jarred) so I sent it in for testing. The motor and resolver tested fine and the resolver is aligned to the rotor. I also swaped the X and W axis module (identical modules)with no change. I also ohmed out the resolver cables and all looks good.
    Im not real familiar with this machine. I bought it for $5000 and have $3000 stuck into it. I bought it from a place where I watched it run so I know i did work so It either has to be from programming or moving or My lack of knowlege. I dont know much about this Type of controller. Please can someone help. I want to make something bad....
    mike_kilroy is offline Stainless
    Sep 2010
    Farmersville, oh (Dayton/Cinti area)
    1,132
    u need to ask the machine BUILDER for help, not the drives supplier. google Mag Machine Tool and call their free 800 tech support number. they have 3-4 guys who know that machine inside and out and will walk you thru the screens to identify the issue - probably in 10 minutes.... post back here what you find for the rest of us - or if u cant get one of these wizards (and we will give u names & direct phone nos).
    SINUMERIKO's Avatar
    SINUMERIKO is offline Plastic
    Jan 2009
    SPAIN
    8
    tbeattie01,
    Were you able to fix this issue? I am looking into a similar problem with an Avenger 250MS using an Acramatic 250SX, hydraulics ON, screen showing "AXIS NOT ALIGNED", and machine not doing anything when I press the "ALIGN AXES" key. Could you please post your solution or findings?
    Thank you.
