SinCityShooter
- Feb 11, 2014
- Las Vegas
I just picked this mill up a few days ago and I'm doing its every 30 year cleaning and checking for needed repairs and maintance.
1st, I can't find much documentation so could someone give me the proper belt sizes for the motor, both timing belt and vbelt.
2nd question, this timing pulley at top has some end play between it and the quill. How much is normal? I took the cover off and looked at the spindle where the rollers ride and you can see some side wear like it was used to tap holes all day.
On last question for now, can I use any good quality AW-46. I bought 2 gal of Vectra 25 and it was $28 a gal and I can get my house brand AW-46 for $9 gal. I would rather spend the money else where like cleaners.
Oh I did think of one more thing. If I pull the electrical board will I have access to the bottom of the coolant tank? I don't have the pump casting but it looks like nasty filthy wheel bearing grease with dirt and metal shavings about a inch thick
Thanks guys.
Thanks guys.
