207MK's are a leadscrew driven machine, leadscrews driven by electric motors but CONTROLLED hydraulically. The clutches are hydraulic. I have had two of them in my shop, and still
use a vertical 207MK regularly. I disagree, not really a toolroom machine as it's a pain in the rear to change toolholders on it, no easy way to tap with it quickly like you can with a Bridgeport.
I bought one of the few CNC 207MK's realizing that under the CNC control was a manual hydraulically controlled mill. In ONE evening I had it converted to a push button operated
manual mill, and removed the CNC controls. I put a Devlieg Flash Change adapter in the spindle so I don't have to use the drawbar to change tools. Not as heavy duty since I converted the fifty taper
spindle to the 40 taper Devleig flash change tools, but WAY easier to use. I haven't had any problem with the CNC mill as far as clutches or gears, and I use it for roughing out castings.
I think the 207MK is more problematic than the older style #2 or #3 size mills. I have one of them that I just can't seem to break. I like the rounded head on the older mills too. The big square head on the vertical
207MK is just IN THE WAY. Ergonomics- simply not as nice as the older mills. Plus there's just something wrong when the base is a fabrication. But having pointed out the pitfalls, for what I use it for it's been a great purchase.
My first 207MK was a horizontal with a multiangle Vertical head. Came out of an automotive plant in Michigan. I liked it at first but it was a real problem child. I had the knee apart a couple of times, replacing a gear and clutches.
Ran it for a year or two and then lost rapids and then the feeds. Completely took the knee apart, found a hidden hydraulic filter, but had replaced the mill with other machines, I've kept it in my bone pile, thinking SOMEDAY, I'm gonna have time to get it running.
I REALLY liked the full universal Vertical head that could be swung around and installed very easily. Hate to admit it, but it's probably been out of service for 8- 10 years. One of the mills I replaced it with was the CNC Vertical 207MK.
I think it led a blessed life, because the CNC controls probably kept the machine from operating most of the time! So it's a relatively LOW hour machine. I heard from Cincinnati that it was the ONLY one of these mills they put a CNC control on.
They KNEW the machine !
