Sorry, its a #2 not #3 as the title says! I bought this machine under power back a few months ago and have discovered that while the rotating RPM selector moves and indicates all the available RPM's, the spindle doesn't speed up or slow down with any of the RPM's you select. It is stuck with just one RPM speed to be determined. The feed selector does work fine when you go through all the feeds shown. It doesn't make any noises and all the fluids are in the middle of the sight glasses. I do notice that when you disengage the spindle lever, the spindle takes a while to come to a complete stop. It sat for several years without being used by the previous owner, i'm wondering if something is just stuck or worse.
Thanks for any insight and wisdom!
