Cincinnati #3 Vertical Mill won't change RPM....
Results 1 to 10 of 10
    Jun 2017
    Georgia
    13
    Default Cincinnati #3 Vertical Mill won't change RPM....
    Sorry, its a #2 not #3 as the title says! I bought this machine under power back a few months ago and have discovered that while the rotating RPM selector moves and indicates all the available RPM's, the spindle doesn't speed up or slow down with any of the RPM's you select. It is stuck with just one RPM speed to be determined. The feed selector does work fine when you go through all the feeds shown. It doesn't make any noises and all the fluids are in the middle of the sight glasses. I do notice that when you disengage the spindle lever, the spindle takes a while to come to a complete stop. It sat for several years without being used by the previous owner, i'm wondering if something is just stuck or worse.
    Thanks for any insight and wisdom!
    Apr 2013
    Michigan
    475
    47
    Sound like you are stuck in synchromesh. Its not finishing.
    Give me a serial number, so I can get the correct manual.
  3. Likes Mike C. liked this post
    Jun 2017
    Georgia
    13
    4A2V1M 8
    Thanks cmike, that would be a big help.
    Apr 2013
    Michigan
    475
    47
    Default C - Mike
    Quote Originally Posted by CNC-Dude View Post
    4A2V1M 8
    Its a 210-12 vertical Dial type mill, model LL Made in 1943
    Have you checked the oil pressure. Should be 290 to 310 psi. You should port pressure to the speed selected. Then the shift of the right gears for that speed. You may have to pull the shifter bracket,
    Check the column oil level and the pressure to start. Possible sheared pin too.
  6. Likes Mike C. liked this post
  7. #5
    Jun 2017
    Georgia
    13
    I'm relatively green to this type of milling machine and don't have a manual, so I don't know where there is a pressure port to check or test the pressure your speaking about. Any diagrams you may have or others might have and can post would be helpful.
  8. #6
    Apr 2013
    Michigan
    475
    47
    Default Cmike
    This is from a old manual with just pictures of the parts. See what you can do with this one, let me know.
    Good luck !
  9. #7
    Jun 2017
    Georgia
    13
    Ok thanks, i'll study it over and let you know!
  10. #8
    Apr 2010
    Gaston Oregon USA
    26
    9
    Default same issue on a #2ml
    I bought a 2ml 2 weeks ago. ran thru all the speeds and every thing seem to work ok. hooked ir up to a vfd and everything works except the spindle speed change
    I've found now it wont change speed and is stuck in a lower speed. it has no oil pressure or oil in the column sight glass , Ive changed oil and cleaned the strainer. adjusting the oil pressure does nothing.
    Any insight into correcting my problem?? I have no experience with this tool and want to get it going
  11. #9
    Apr 2013
    Michigan
    475
    47
    Default cmike
    As long as your pressure is okm, it should work. Watch your pressure as you turn the spindle speed dial. Does the pressure stay good when it stops. The item 174 is suppose to turn. When it is working correctlly and the part 174 is turn by the driving gears when it stops. It will port through the holes on item 170 and then out via tubing to shifters for that speed,
    The dial may be turning but 174 is not turning. If you take the shifter bracket off to look at the picuture of figer 131A, You may try putting air to the in the port on the bracket that is supplying the oil pressure. This might give you a clue to what is wrong.
    When you have the bracket , check in the bottom of the casting and see if there is a piece about 1 1/2 inches long and has keys for three spling shaft. That piece is easy to loose and not know its off. So run a magnet in the bottom and see if anything is there.
    I will check this tomorrow.
  12. #10
    Jun 2017
    Georgia
    13
    cmike, where is the mechanism shown above located? You also mentioned before about pressure, how can you tell what it is? Is there a guage somewhere to show this or do you have to find out by some other method?
