Cincinnati vertical age estimating
pressbrake1
Stainless
Dec 8, 2012
essex england
Hello can anyone put a age/ model to this mill Ive not seen one with that capstan type handle before.
It comes in with a deal im negotiating so any info would be appreciated.Screenshot_2017-01-21-19-35-36.jpg
I have books from the 50's with ones like that in so I would say around war time.
Regarding the model it is a big one by the look of it as I think the smaller ones have dovetail slides so I would say No4 ,If you have any dimensions for the table I may be able to be more certain.
Here is a scan from '23 with a capstan wheel. OP photo could be from between the wars. No photo of left face of column makes it a moot question.
Thanks for replies . Ive been told there is a plate stating it was rebuilt in 1963
Its almost a freebie in with the deal and im not short of a vertical
Mill but if it still works its worth saving from the pot and I have a soft spot for big Cincinnati's and k&t's
You'd be hard pressed to beat a " Cincinnati " in my opinion, even an old one. I'd put my bet on 1945 to 1955.
If it's been re-built I'd enquire who did the job. Some rebuilders do most of the work with a paint brush.
Regards Tyrone
They were in my neck of the woods but I can't say I've heard of them. Could be they closed down before my time. I was still at senior school in 1963. I be inclined to give them the benefit of the doubt going off the placard.
Good luck with it anyway.
Regards Tyrone.
Regards Tyrone.
I also assumed that about the plate showing there must have been a certain validity in their claim
I just checked companies house which showed they lasted from 1960 to 2000 then changed name/absorbed and lasted until 2010 , which was a dangerous year for business
Look on the right top corner of the table face and see if there is a number. May have to use emery to see it.
Im picking the junk up next weekend so I ll be able to look at numbers then.
Im kind of excited as theres cabinets full of stuff as well as machinery and maybe a powered rotary table for the cinny
Looks like a late 30's thru the 40's dial type to me. Mostly they were making wide knee high powers by the 50's and this isn't one.
Picked up stuff today, cinny plates show war finish giving a fairly good date range.Paint is terrible but thats irreverent to me.
I was shocked to find excellent ways etc.
I was just going to leave it there but its to good
You will need to be able to read the serial. This may be on bottom of tag - or elsewhere - like front face of table on right end
A typical dial type serial in that period will start with 2A or 4A
The number that can be partially made out at bottom of tag appears not a typical Cinc serial - not enough letters
OOOPPS - keep forgetting this is UK
A 1940 dial type serial will start with B 4012 if made "over yonder" (Birmingham)
Your 4010 is an unknown, not mentioned in serial book - a wild guess may just be another location but still 1940 - you have to remember they were under daily bombing attacks at least part of that year - some facilities may have just "gone away"
Fair chance is the UK version of the 2A which is Medium Speed Dial Type - 450 RPM top end
Thanks JO ,Shes a old lady. It must have worked hard during the war to get a rebuild when twenty odd years old.
I think im going soft as I might even paint it!
Its only got a 48" table but its much heavier build than my no2 1950's vertical
Ive picked up everything other than the mill, the vendors forklift could only get it a few inches off the ground so was unable to load it.
The machine is a no2 with a 50" approx table. Im wondering if anyone has a fairly accurate idea of the weight of the actual table as Im thinking of removing it to reduce weight
I'd guess BARE it would go 350 Lb / 170 KG. A solid blob of cast iron 4 X 12 X 50 would be a bit over 600 Lb / 280 Kg
