leeko
Stainless
- Jun 30, 2012
- Chicago, USA
Hi all,
A while back, i picked up a K&T 2HL vertical mill which came with a 6" carbide insert facemill in the spindle. Over the course of the last couple of months, i now find myself with a total of 3 facemills in the 5-6" range. I'm not sure the pros and cons of each style, and all 3 require new inserts so trying them out will cost a bit of money. Hoping to poll the group, to figure out which one(s) to keep
1) Tungaloy TEN09R600U0200A07, 7x 5-sided inserts, 6", not 90 degrees
2) Sandvik-Coromant ModulMill RA282, 6x triangular inserts, 5", i think this will leave a 90 degree wall
3) Iscar F90LN D6.00-11-2.00-R-N15, 11x funky 4-sided cutters presented to the work on-end. I don't think this leaves a 90 degree wall.
So.... what are the pros and cons of each type? I'm thinking i should keep number (2) for those odd occasions where i need to cut to a 90 degree shoulder, and maybe one of the others. Or do all 3 have a place in the toolbox for different reasons? Does the iscar's unusual attack angle cut significantly better than the more conventional tools?
I'll be using these on a 3hp K&T 2HL without coolant for the most part. I'm doing mostly one off workpieces in steel or cast iron for machine rebuilding/restoration. Do i really need ANY big facemills? No, but since when did that matter? : -p
Thanks in advance,
Lee
Sent from my SM-N920T using Tapatalk
Thanks in advance,
Lee
