Reeltor
Cast Iron
- Jun 10, 2009
- Lawrenceville, GA USA
I have several questions on cutting a gear on my VN 22L.
1. What speed and feed to use? 2. Is the setup in the photo strong enough? 3. Shall I cut 14 or 15 teeth on the blank? I could buy a gear from Martin that has 15 teeth (4 dp 14-1/2 ° pressure angle. The charts that I reviewed say to cut 14 teeth in a 4” +- blank
The blank is 8620 steel, 4-1/32” Dia. 2” thick, I want to cut a gear with 4DP & 14 or 15 teeth. I am going to cut most of the waste material out using a 4” Staggered Tooth Side Mill cutter with 18 teeth that is .290 wide (4 x .290 x 1 ¼). I am seeing various numbers to use for SFM for 8620 (30 to 127). Using 50 sfm I come up with 50 RPM(47.7) and a feed rate of 1.7 IPM. The feed rate seems FAST to me.
What RPM and Feed would you use? 14 or 15 teeth and what dept of cut would you use? I want to use the gear to mesh with a rack for a kinetic style log splitter.
Looking at the photo, is the setup sufficient or to I need to do something more to secure the blank? Sorry for the long post, thanks for any help
Mike
Mike
