You might have to accept softer gears, and of lesser precision than P&W shipped, but they would still be eminently serviceable for all the non-abusive loading you are likely to place on them, going forward.
Yeah, I went around to find a shop that could i.d. the dp and pa, my educated guess said 14dp, and i was right, but couldnt figure out the 20deg pressure angle, but the big kicker, was its as hard as a coffin nail, 63c to be exact. I thought it was cast iron from the cracked off teeth and large grain structure, but not so much. The shop owner said he could make one out of 81something and it would be a couple hundred bucks, of in reality seems pretty cheap for what all would be needed to make it, and the 1.0625" i.d.(which doesnt really matter it seems that 13/16" i.d. roller bearings are cheapand easily attainable as long as the o.d. is in .0625" increments).
Elsewise, what O-1 maybe since it is known to hold tolerance during heat treating? Not sure of anything steelwise else, that i could have machined and hardened, anything else would need ground afterwards, and i dont think i could dress a 14dp weird radius(looked into it, cant wrap head around what ive read so far, let alone doing it symetrically to a grinding wheel), or the ability to i.d. grind that accurately.
Some guys on facebook say boston gear is a good place to look, maybe ill try calling on tuesday, but will most likely just have the local guy cut it.
I would attatch pics, but that doesnt seem like an option on here, and dont remember any of my flickr passwords to embed.
The other option i could just run it, it has half its teeth, but the good side of the q.c. gears(they were soft enough to touch up with files), are the side of the gear that lost teeth(pretty much if you split the gear perpendicular to the teeth, one side is fine, the other side is broke off, or when the gear was half on the q.c. gear to the right where it should have been for that selection, the other half were in and out of mesh with the tips of the teeth of the gear to the left). Or i could grind the stick out of the i.d. section of the gear(one side is proud .125") and make a spacer to flip the gear around and run it good tooth side to good tooth side.
So thats where im at at the moment, and a side note, they sure loved loose roller bearings back then.
