I Picked up a K&T 320TF Horizontal mill w/ the ram and vertical mill setup today up in the metroplex. 16x72" table, 50 taper on both spindles. Came with a fair number of toolholders, 2 face mills, 4 horizontal arbors, and a bucket of various cutters for the horizontal arbors. I'm hoping to get a little more information, especially about the TF knee and the ram and vertical spindle, as it seems that a lot of the features of the TF are similar to the smaller single knee screw machines that seem to have much more readily available documentation. If I understand correctly, that number stamped above the motor housing is the serial, 56-2750-26-1. I see no other model or serial information on it apart from motor data plates.
A couple hours of 1" solid roller-pinch bar action and a rollback wrecker got it moved with little fuss and set in it's semi-permanent location. It may get turned 90 degrees, don't know how that's going to work out just yet. I've spent a few hours cleaning and removing chips from unmentionable places thus far, but that's about it.
As of right now, the issues I'm trying to sort out are firstly finishing the 240v conversion someone else 'started'. All the motors have been switched, the heaters on a couple of the contactors have been bypassed, the coolant pump is hardwired on, etc, etc. It appears that all I should have to do besides change out the contactor heaters is replace the main motor contactors for the next size larger, as they're rated for 15HP @240vac. We shall see tomorrow.
I bought the machine from a nice Thai gentleman who purchased it with a few 3-axis CNC milling centers as a package deal, he never used it for anything. The person he bought it from either started converting it and stopped, or got it rigged enough to operate and made chips. It originally came from Bell Helicoper.
The second issue is the table feed dial is stuck. Possibly related to this, one of the round covers on the left side of the knee appears to be in slightly cockeyed and one of the four cap screws that holds it in is sheared. The table feed was working in the speed it's stuck in before I disconnected the machine.
I'm not sure whether the dividing head feed mechanism on the right side of the table is a K&T accessory or not, I'm guessing not with the cog belt.
Anyway, whatever information I can get, I'll take. I'm in it for less than I could sell the tooling for, so I'll consider it a win even if it winds up stuck with one feedrate.
EDIT
I talked to Hugh Head in WI today, he's going to put together a service manual for the machine. He recommended DTE 26 in the knee/column, which is convenient as that's what I'm running in the little roundhead LeBlond. I put just shy of 4 gallons in the empty column and we're not on the sight glass yet. I am getting reasonable flow in the flow glass with the spindle on.
I took apart the table speed selector to rule out a broken gear tooth causing the stuck lever, they're all fine. I was able to get the lever to move with some light persuasion and it's now shifting, but it's still stiff. I assume gummed up lube or condensation rust (or both) in the knee is to blame.
I found another issue, though... I am not entirely sure how the ram is supposed to operate, but the only thing that looks like it could operate it is a knob on the column up by the ram ways. It does not look factory to me, it looks like something off an import drill press. Obviously, there are 2 big locking bolts, I know the rear one is free, I think the front one is too, but it doesn't move nearly as much as the rear. Was there a non-powered ram option? There's a rack in the center of the ram dovetail, but I don't know if there is supposed to be a hydraulic motor that turns a spur gear, or if the knob on the side of the column drives the rack. Also, what lubricates the ram ways? is that fed from the ram gearbox oil? I'm looking for a place to get some penetrating solvent or oil in that massive way surface besides at the edge. I have a feeling it's just really, really, stuck.
quick clip inside the starboard gearcase vent cover: Inside the K&T 320tf gearcase - YouTube
EDIT
