Title pretty much says it all. How much weight can a K&T Milwaukee 2H handle on the table?
Hard to believe but Hardinge says you can put 750 pounds on a new Bridgeport table. So I'd have to say you have to be pretty safe with 450 on a 2H assuming you don't have a ton of overhang.
I couldn't find anything in the manual. Reason I ask is I have a 450 lbs iron casting I need to face and wondered if it would be OK.
Just to err on the side of caution, I wouldn't put more than three or four of those castings on the table at one time!
Seriously though, It'll be just fine.
Great everyone thanks for the input. The casting is 900mm long and 350mm wide. I will be facing parralel with the spindle using a face mill. It's the wide side I need facing so I will position the casting perpendicular to the table, and should be fine if properly balanced.
Again thanks for the help.
No doubt you know that you do not have the travel to do the whole face
Don't forget face mill eats some of that just to get out of the cut
Horizontal has 28" side to side, 10" in and out and 17 1/4" up and down
You have not said hor. or vert. mill
Yup. The auto stops on the table are currently set to 29 inches. They are adjustable to 32 inches. Weird. Even the manual says 28.
Yes. Will have to wait. Casting will be here in 5 weeks. I will post pictures when it arrives. I think it will work however, if it doesn't I have larger mill available through a friend.
Notice
