Sorry this is kind of long.
I've got a steady fast dripping oil leak at the gearbox where the splined vertical shafts power the knee.
I had taken the whole rapids clutch housing (which includes that gearbox) off so that I could build and replace a broken head feed bevel gear (also located in that casting). I cleaned everything, and cleaned and rodded out ,and blew out all of the oil passages in all of it. When I reassembled it all and ran it a couple hours I noticed I had an oil slick on the floor beside the flywheel cover door.
Sooo, thinking I must have missed something I tore it all back apart,(half a days work) and checked everything again I can run a wire all the way through the drain back passage back into the knee, I've blown compressed air through it and can hear the air blowing into the knee. Anyway I very carefully reassembled everything, and still I have oil slobbering out from around the gear that the main feed drive shaft runs through.
For the time being I zip-tied a little sheet metal trough on it to send all of the oil into a plastic bowl sitting below the motor pulley. I wouldn't care if it were a little leak, but this thing is filling the pint bowl in about an hour. My 1938 model 2H universal which sits right beside it doesn't leak anything out of that section. The machines are both level, and both have the same oil in them.
Any ideas guys???
Any ideas guys???
