Results 1 to 6 of 6
    javan.dempsey is offline Plastic
    Jun 2012
    Asheville, NC
    21
    Default K&T Model H No. 2 Vert, serial info, etc, requested.
    New member here. Mostly a smith, damascus, and knifemaker, but I like big machines and big projects.
    I bought a K&T Milwaukee Model H No. 2 Vert from a friend a while back, in known good running condition, for cheap. He doesn't have room for it with the other mills, and I needed something I could not only do small work with, but the rapid traverse and big cut capacity of the K&T are extremely useful for some of the damascus work.
    Anyway, I was curious to get some date and weight info based on the serial, along with any pointers of things I need to check immediately after installation. The machine was used daily up until a couple of years ago, and has been sitting pretty idle since, however it has been inside and not exposed to any elements other than whatever humidity and metal dust is floating around my buddy's shop.
    I know it's got a set of some sort of quick change adapters, and some other tooling, but I don't recall what. These use cat 40 holders correct?
    Ser. is 28-2841
    Thanks all, super excited about this machine after seeing how revered they are here.
    johnoder's Avatar
    johnoder is offline Diamond
    Jul 2004
    Houston, TX USA
    18,478
    "CAT" holders had not been heard of when it was made. National Standard , NMTBA were the original steep taper series. An early 2H like this (date to the month this evening unless others beat me to it) were NMTB 40 standard and NMTB 50 optional. It will be just before WW2 I think.
    On edit
    One of a lot of 30 competed June 1940
    Jun 2012
    Asheville, NC
    21
    Quote Originally Posted by johnoder View Post
    Thanks John, that type of info is exactly why I'm here.
    Jun 2012
    Asheville, NC
    21
    Any chance I can still get an actual date and approx weight on this one? Thanks!
    johnoder's Avatar
    Jul 2004
    Houston, TX USA
    18,478
    In post #2:
    One of a lot of 30 completed June 1940
    Weight in '39 catalog 4150
    Jun 2012
    Asheville, NC
    21
    Thanks again, and sorry I missed the edit.
