Hi everyone.
I recently acquired a 12" model K dividing head that is need of a good clean up. I'm having bit of difficulty disassembling it though, as I have not been able to find a parts manual to see how it goes together. I'm sure someone out there must have taken one of these things apart though, so I'm hoping someone can give some advice.
I have tried removing the casting that houses the worm gear. When it pulls away from the base, the main shaft (the 5:1 drive) stays behind. I can only move it maybe a quarter inch though, presumably because the worm screw is captured within the concave part of the worm wheel, which is on the stationary shaft. It seems like if I could first remove the spiral milling drive shaft (the 40:1 one) that has the worm screw on it, then the whole casting would come away. But I can't see how that shaft can be removed; there is no obvious retention mechanism that I can see and I cannot believe it is just a press fit. I have removed the cap over the end of the shaft (the one that has the oil level plug in it) and I see no nut or anything. Just a bearing.
At the other end, the cylindrical part from which the shaft emerges looks like it is not part of the casting, and it would make sense to me that it is what is retaining the shaft. But then the question becomes, what is retaining that part? I see no evidence that it screws into the casting, and there are no flats for a wrench anyway, but I see no other means to remove it.
If anyone out there has done this before, I would really appreciate any insight you can give me.
