Don Kinzer
Cast Iron
- Mar 18, 2002
- Portland, OR USA
In another post (http://www.practicalmachinist.com/v...ker-serial-number-registry-173409/index2.html) someone suggested that running the motor backward even briefly can cause damage. The installation manual for the 2CHL et al says "Check the rotation of the motor before installing V-belts." but it doesn't warn of possible damage from backward rotation.
So what is the consensus as to the possibility of damage if the motor is run briefly (without engaging the spindle clutch) in order to determine its direction?
