Kearney & Trecker Model 2H Universal
bambam76
May 1, 2017
I picked this mill up from a college in Michigan. It has General motor asset tags on it and came with this bed with a built in dividing head.
I don't see Kearney & Trecker offer this table in their literature to the public. Any ideas as to it's intended use? I can see setting it up for bevel gears any other
thoughts or experience with this option?
Looks a lot like a Triple index centers machine, all the spindles are operated simultaneously by moving the index crank, The ratio is generally 40-1 on all the ones I have seen/used.
Could be K&T manufacture as I have a Brown and Sharp triple and it looks very different.
There should be a triple tail stock for it.
K&T built tons of custom equipment to order for manufactures back then.
If it is K&T there should be numbers stamped on it.
Mike....
