ramsay1
Titanium
- Aug 19, 2003
- port allen, louisiana usa
Yes direct drive doweled to over arms..Should be able to figure center distance by the other drive bracket for the universal head.. It is one to one ratio with the spindle... Drive and driven gear each 32 teeth 9 normal pitch. Ramsay 1
Now you lost me. What does the 26 tooth in your post above run with?
Sorry, Ramsay, but I'm still very confused: either the ratio for this universal head is roughly 1:1.46, or the distance between the spindle axes and the axes of the driven gear is different between this head and the other one, or the DP of the gears in the two heads is significantly different, but the pitch diameter is the same (i.e. the diameter of the 32 tooth gear is roughly the same of the 26 tooth gear).
Paolo
Mike - could you measure OD on your 26 tooth? Less any raised metal
I am going to suppose for a minute that it is 3.470"
3.425 Is the dimension...
Thanks Here are some maybes that you can eliminate, or not, as you get further along with finding center distance
26T with 3.21348 PD and 25.9746* helix angle
38T with 4.6966 PD and same angle
3.955" center distance
I did discover 1H/2HL and 2H/2CH distance C/L spindle vertically to C/L overarms is the same - I.E., gears that work on the smaller also fit the larger. I used dims stated in '39 full line catalog as to radial and spread. The vertical dim. is 5.657"
I have a 2H with that exact type of vertical head, is the drive gear the same?
I did get the original drive gear with the machine when I bought it and could take some measurements if needed.
Hello everyone: I have cut a drive gear which fit and functions but is noisy as I am a bit off on my lead I think..
It has been like an oven in my shop lately so I have been reluctant to do too much at one time..
I determined that the shaft center distance in this head is four inches, the tooth count on the drive gear is 38 and the o.d. of the drive gear is 5.012...The normal pitch is nine..
I tried a lead of 29.000 and I do not get full contact of tooth on the drive gear... Will try another lead soon... Ramsay 1
Notice
