P&W b lathe disassembly process?
Community On The Web
Results 1 to 12 of 12
    Oct 2014
    Kansas
    15
    15
    Default P&W b lathe disassembly process?
    I have searched the forum, and only found info on pulling the headstock to repair forward clutch. I would like to remove the QC box and apron for a thurough cleaning, as well as the clutch housing. Anyone here done this? I'm not sure of the best way to proceed. Removal of the feed, lead screw and control shafting seems like the place to start? Under 75 years of crud, this lathe is gold. Thanks, I could chronicle my adventure here, with pictures.
    Jul 2004
    Houston, TX USA
    26,297
    I think Carl is current and has worked on his, though to what extent I don't know
    Would not hurt to ask in a Private Message
    Pratt & Whitney Model B 12x30 on eBay at HGR
    Parts book - if you come up with one - just shows assemblies, not how to take it apart
  3. Likes alittlerusty liked this post
    Oct 2014
    Kansas
    15
    15
    Thanks John,
    I was looking at the lathe last night. This may not be that difficult. Knock out the tapered pins for the lead screw and feed shaft, and remove the bearing carrier at the right end. Since the threading dial is constantly engaged I expect having to turn the lead screw out of the apron. Once the left end clutch linkage is removed, the clutch shaft should slide out. I'm going to have a look under the tray to see what is on the left end of the feed clutch shaft. It occurs to me that lining all this up during reassembly may be troublesome. If I get all 4 shafts loose at the QC end, I might set the apron with shafting off as one unit, with the engine hoist, and mount it back the same way.
    Oct 2014
    Kansas
    15
    15
    Well, I've made a little progress on the lathe. I've joined the P&W forum on yahoo, and found a treasure trove of manuals. No parts manual for the b but the c is well covered there. Thank you, Baxter Tools. Good info, and I will be able to put a name to the parts as I attempt to describe my progress here. Too tired to get started on this tonight.
    Oct 2012
    Virginia
    6,540
    2896
    3078
    Quote Originally Posted by alittlerusty View Post
    Uhhh.. most of us would extract or dis-engage the TD before we would go to THAT sort of tedium... Shouldn't be that hard, Niles (P&W) were not masochists....
  7. Likes alittlerusty liked this post
  8. #6
    Jul 2004
    Houston, TX USA
    26,297
    Just turn the lead screw enough to see set screw in pinion looking from right end of apron. Loosen or remove screw and slip the indicator dial and its shaft out the front.
    Catch pinion as it falls off. Keep track of set screw.
    Maybe after a bit I'll scan Section TT in the 20" parts book
    On Edit...add scan
  9. Likes Monarchist, alittlerusty liked this post
  10. #7
    Oct 2014
    Kansas
    15
    15
    Thank You. Done. The brass start indicator gear is nearly the same diameter as its gear teeth. There is a groove cut in the circumference at the outer end, that intersects the location of the set screw. A fine wire is wrapped around in the groove, that retains the straight screwdriver slot of the set screw.
    Now I just have to turn the threaded gear off the left end of the lead screw. This gear has a set screw and blind spanner holes 180 degrees opposed. Too tight to hold with strap wrenches. I bet there is a brass slug under that set screw, so it don"t bite into those fine lead screw adjustment threads. I'm off on Sunday, may be able to figure this out then. I have the other 3 shafts out, no problem (as the young folk say).
  11. #8
    Jul 2002
    Maryland
    4,234
    511
    462
    When you come across the SN post it up. A few of us on here might be able to approximate the build date.
  12. Likes alittlerusty liked this post
  13. #9
    Jul 2004
    Houston, TX USA
    26,297
    Quote Originally Posted by morsetaper2 View Post
    It will be on a bronze plaque on face of bed casting down near tail stock end of bed. It will be similar to thumbnail, which is for a Model C
    All the 12 X 30 machines were built in West Hartford in the WW2 years and somewhat after
    Here is my Disappearance thread, mostly gutted by Photobucket
    USA Heavy Iron Disappearance
  14. Likes morsetaper2, alittlerusty, Monarchist liked this post
  15. #10
    Oct 2014
    Kansas
    15
    15
    The long of it: M-1395-1479. Summer of '42, perhaps?
  16. #11
    Oct 2014
    Kansas
    15
    15
    Thanks again, John. I think I have read most of the P&W posts that are easy to search for. I think some goodies are still hiding in less referenced posts, I turn new stuff up now and then.
    After buying a new reversing contactor and overload relay, I find out that reversing this feed bar lathe is a crash in the making. Not to mention the reverse oiling feature. Oh, well, Back to ebay. There is always the prospect of finding something to fit around this reversing contactor. Like a B&S #2 Universal Milling Machine. Everyone wants a Bridgeport, myself included, but when I had a choice, the Bridgeport was mostly used for plotting, drilling, and tapping holes.
    My last machine shop job ended in 2001. I was the maintenance shop supervisor for the Dixon Ticonderoga Co. (pencil) plant in Versailles MO for 15 years. Dixon Ticonderoga was a child of the Joseph Dixon Crucible Co. of Jersey City N.J.. They claimed to be the oldest publicly traded company in the U.S.. Now belonging to Fila of Italy, production having slowly migrated to Mexico, and now China. We had a couple of nice Mauser lathes, a Cincinnati horizontal, the B&S #2 with all the attachments, a couple of Bridgeports, a Lagun mill, a couple of small South Bend lathes and a nice radial drill, I think it was a Milwaukee. We also had a well furnished weld shop, and a two man electrical shop. It was a PITA, but I miss those days. Having a machine shop at your disposal is empowering, at least for this old deplorable. I now work as a Low Pay Nurse for the State of Kansas. I could retire in five years, and I am angling for something empowering to piddle with in my climate controlled walkout basement.
  17. #12
    Jul 2002
    Maryland
    4,234
    511
    462
    Not much listed. Numbers shown are last for the year. So your guess might be pretty close :-)
    1942: 1521
    1947: 2200
  18. Likes alittlerusty liked this post
