alittlerusty
- Oct 9, 2014
Greetings to all,
I've been lurking on this forum for a while. You folks are a gold mine of valuable information. Thank you.
Having recently acquired a serviceable P&W b lathe, I finally have some iron worthy of consideration.
The lathe has been modified from the original pulley drive, set up to double the RPM's. The original G.E. 3 hp motor has a A50B54 (5.750 O.D.) 2 groove B belt sheave. The driven sheave is a A46B50 (5.375 O.D.) sheave. Judging by the operators manual, It looks like the factory set-up was for a 5 groove sheave with the driven sheave having an O.D. of 8". Would anyone here have the specifications for the original set-up? I also have a Clausing 100 lathe for the small diameter, higher RPM work, and would like to return the P&W back to the original speed range and torque capabilities (conforming to specifications of war board). I am also scrapping of layers of gray/green/gray paint, and constructing a 7.5 hp phase converter following Fitch William's excellent recipe.
Thank you all for keeping American iron up and running.
