Don Kinzer
Cast Iron
- Mar 18, 2002
- Portland, OR USA
I'm trying to remove the X-axis handwheel on the left side of a K&T 2CHL universal horizontal mill table. The attached image is excerpted from the Replacement Parts Manual for the 3HP 2CHL but the constituent parts seem to be the same for several models.
I've removed the #40 Spring which reveals the #36 pins but I don't see how to pull them out. They definitely don't drive through but it's not clear how one extracts them. The part #37 is called the "handwheel retaining pin" which sounds promising but I haven't identified it. Any tips from someone who has done this before?
By the way, the reason that I want to remove the handwheel is that the #34 handle has been broken off and I want to drill out the stub and install a new one.
