Van Norman 28 Long Table
FirstEliminator
Cast Iron
Jul 4, 2007
North Adams, Massachusetts
Hey guys,
A couple years ago a guy had posted a VN 28 for sale that his father had originally ordered with an extra long table. I think it was located in Maryland. It was a while after that I had again seen the mill was still for sale. I did some searching and couldn't come up with the post. Does anyone know if this mill ever sold? Or, if anyone remembers the specs of the table and table travel?
thanks,
Mark
Awesome, thanks for the reply. When the machine was listed, I was thinking it was pretty special with the long travel. Wish I had the space, time and money to do something about it. Not like I gained much of any of those int he past 2 years, but hate living with regrets. Ya never know what might still be out there on old for sale posts. With some persistence I was able to purchase Norton U4 cylindrical grinder parts from a 7 year old thread. I have a 28 now with standard travel. The 12" face mill won't completely clear a 24" part. If I were to face a V-8 engine block I feel that the following side of the face mill should pass the work. The ad sounded like the guys in the shop really like that mill and took good care of it.
thanks for digging up that post,
Mark
Well, I had pondered about this mill for a while back when it was listed. Kinda wish I called on it then as the long table is pretty interesting. Maybe I missed out, maybe it still exists.
There are a couple machines I'd like. One of them being a J&L #5 turret lathe. Also a Bullard 46" VTL. Before accumulating any of those, I'm pretty much out of room. Need another building.
I wrote to the seller using the e-mail address he had posted in the ad. He said it was sold this past fall to someone in Maryland. I wonder if they are on here or on the VN yahoo group? Glad to see it found a home and didn't go to scrap.
Has anyone ever seen a long table VN other than this one?
thanks,
Mark
Mark
Why would you want to machine a radius on your v8 engine? Especially with the long table it will droop an amazing amount at full travel.
That would be worlds better.
I got the engine block the other day and need to get it machined quick. The engine machinist said he'd bore it, I asked about decking and if he wanted me to bring down the pistons and rods from the 4 corners so we can zero deck the block. He said for me to take it back, mock it up and give him measurements. Well, I surface a lot of cylinder heads on my shaper and thought maybe I'll deck the block myself versus bringing it back down to where he is. He's about 45 minutes away. Not sure how well the block will mount on the shaper. If I am not confident about cutting it on any of my machinery, then I will have to have to take the trip back down.
for a while I've thought about doing some block work on the VN28. Boring the block, I could mount it on one cylinder deck with the other side facing the cutting head of the fashioned in the horizontal position. Then I could feed the block in on the Y axis. I suppose I could face the deck that way too. But, it could also be faced by setting the block on the oil pan rail and tilting the head at 45*. As long as care is used on the set-up it should work. It may not be efficient, but should work and be fun.
Hey guys,
Looking at this VN38 on e-bay ( Van Norman Model 38 Vertical Mill 48 Volt | eBay ), it has a 72" table. The info on Kasunich's webpage says that the 38 does have a 72" table but only has 34" of X travel. His page also says the 28 comes with a 65 inch table and also has 34" of X travel. Longer table, but the same travel?
Another thing is this e-bay VN38 shows a pic of the tag. Which says MEA-4275-358. I thought the MEA was the one that had the swiveling table? That seems like a neat option. Decoding the serial number, I would guess 358 was the sequence number. Does the 4275 portion have anything to do with the table travel and table length?
thanks,
Mark
Hey guys,
thanks,
Mark
Look at the amount of unsupported table and the narrow knee, no way there won't be loads of droop when the table is not centered. That DRO is prehistoric!
Not everything on his page is 100% accurate. The standard #28 doesn't have 34" of travel. The VN 2X models were basically #2 sized, while the 3X models were basically #3 sized. For VN, that meant mostly a bigger motor and a longer table. Otherwise a 2X and a 3X are basically the same machine.
The 4275 is the serial number. The 358 is March 1958 date of production.
I don't have all my VN brochures here where I'm typing, but I don't believe that all MEA's had universal (swivel) tables. Certainly the one in that eBay listing is not a universal. Probably the universal sisters of the MEA were tagged MEAU.
So that sold. Pics did not do it justice. Weight was more than I wanted to deal with. But location being so close did have my attention!
Also learning that the suffix on the serial is the build date!!!!!!!!!!!!!! The Yahoo group did not mention that.
