Hello all,
I found myself a VN Duplex No.2 and it appears to have an upgrade on the cutting head. At first I thought it may be a high speed upgrade until I noticed that not many early VN came with a 50 Taper. By my research its a NMTB 50 taper, pretty cool.
It was also suggested in a different place on this board that it may be a roller bearing upgrade. Has anyone seen something similar to this?
View attachment 221905 View attachment 221906 View attachment 221903 View attachment 221904
I wasn't even aware that model existed, and I've been paying very close attention to Van Norman milling machines for over a decade. You have a very cool old machine, perhaps the only one of it's kind left, and it would be a real shame to do a lot of "upgrading" of it. You can get good service out of plain bearings, especially if you don't need to run it in production three shifts a day.
According to this link:
The NMTBA was founded in 1911. It's not clear when the first NMTBA 50 taper standard might have been proposed. It was apparently patented in 1931 and adopted as a standard in 1938.
See also:
http://www.practicalmachinist.com/vb/greatest-hits-and-links/milling-machine-standard-tapers-110670/
Here's an ad from 1913 that indicates that Van Norman made three versions of the Duplex miller, the No. 1/2, the No. 2 and the No. 3.
A few No. 1/2 millers have turned up over the years, but this is the first No. 2 Duplex that I recall seeing.
This search will turn up other Van Norman Duplex Miller ads prior to 1930:
But I haven't found anything that mentions the spindle taper. It's possible that you have a spindle that has a early version of the 50 taper and is original to the machine.
I would love to see more photos of your machine, especially a photo of the door on the side of the column and any patent numbers that you find elsewhere.
What part of Montana are you from? (I grew up in Bozeman and went to MSU.)
Cal
