Hey guys, i'm new to the forum here but not to machining. I just recently purchased a Cincinnati #3 vertical milling machine, early 1950's era, and am running it through it's paces to confirm everything works on it. All the power feeds work fine and speeds and feeds change with no problems or noises. No noises with the spindle either. My concern is the sight glasses that are about eye level on both sides of the machine. They don't indicate any lube circulating through them. There is a cast inspection cover on the back of the machine about the size of a large softball, also about eye level that I removed and looked into. All the gears and bearings seem to be getting a good oil bath, but I don't see any fluid level inside this deep cavity to know if it's just low and needs some added or has another issue. I see a copper drainback line from one of the sight glasses inside this area, so i'm assuming the source of the fluid that flows thru the sight glasses originates from inside this area. My question is, can someone tell me the recommended fluids/lubes to put in all of the spots around the machine. It has the typical spring loaded flip top fill cups(what lube is best for these locations), it also has at least 3 threaded aluminum fill caps that says "Oil" on them, they also are on the table area and knee with sight glasses also(what lube is best for these), and then the various grease fittings around the spindle area and along the upper side of the frame.
Sorry for so many questions, but this machine seems to be in great shape and I just want to preserve its condition so it can serve me for many years to come. Thanks!
